zoraduntov
Just wanted to know.
Any big block motor (.21 and up I think) should fit right in. I've heard on the picco mills that you have to file the motor mount a bit on the inside edges to make it fit. But that should work fine for you. I Just put an LRP .28 in my XL and the motor mount bolted right up. The backplate hit the TVP's with the stock 16/52 gearing but I just used my dremel to file the TVP a tiny bit in two spots. A simple gearing change would have solved the problem as well but I didn't want to wait for it to get here.
X2 all good info here. For motor mount clearance issues due to gearing try button head screw over caps b4 you file out TVPS .. Normally all they need
My issue was with the whole backplate touching the TVP's so the button head screws would not have helped in my case. LRP .28 and 16/52 gearing on stock XL TVP's.
