I'm stuck, wiring help!
FluxedSavage
Here are the 2 wires from my Flux ESC.
Here is my new switch with the plugs cut off.
This was the only way i found to make it turn on and it works but I would like to use my switch.
The stock one broke? It just sort of fell apart lol. But this new one is like a HD switch. I got it to work by cutting off the black wires and just using the red. I soidered them together and used heat shrink wrap to make it look good. Then I took small zipties and put eveything neatly under the ESC stand. You can't even tell I changed anything unless you look really closely or take off the stand.
My on/off switch also broke. No need for it though. I just turn the transmitter on and plug the batteries in and go.
