chronic
My savage is a couple weeks old. I was having troubles with it at idle, and noticed it was literally spewing oil all around the front main bearing. So I removed my engine at work today.
My buddy who had time between his run cycles offered to take the clutch off and check it out.
My clutch bearings were effed. He said when he pulled the clutch bell off the bearings fell on his work bench.
Then he wanted to remove my flywheel to check the main bearing, and when he removed the wheel, the friggen crank cracked and a piece of the end came off. I'm not sure how much, but some of the threaded end broke off??
Any opinions here? I'm totaly confused, my friend is really upset because it broke when he was playing with it, I don't understand what the hell is up here.
