Hpi Bullet 3.0
trev616
Anyone know of any engines that would fit the Bullet? Looking to upgrade and i doesn't look very promising.
Os makes a real nice .18. what crank type do you need sg type, short crank or long crank, rotary carb or slide the .18 cvrx line is a great drop in replacement and aint bad priced either...
slide carb version
http://www.osengines.com/engines-car/osmg2102/index.html
rotary carb version
http://www.osengines.com/engines-car/osmg2104/index.html
short crank rotary carb version
http://www.osengines.com/engines-car/osmg2105/index.html
seems they got all the bases covered..... I have the second one in one of my trucks and I love it....
Do you need new exhaust? Will the motor mounts hook up to it? Will the rotostart work on it as well? Just trying to gauge what kind of project i am in for. Thank you for the response!
got a pic of your existing engine, then I may be able to help a bit more, the OS uses a side exhaust so I think is the same, should not take many mods to get done tho, I have done far more complex ones without trouble and I am sure you can make it work....
I just have the stock g3.0. going to check this out for sure!
