how to remove reverse
mtpockets
Virginia Beach, VA
i bought a used savage from a guy and he had put in the 3 speed and reverse. well, now i want to take it out cause it never works and sometimes goes into 'nuetral' when i driving. what is the easist way to remove it? this is my first savage and not that familiar with them. thanks.
You have to pull the tranny and take it apart and remove the moduale. Then you will have to take the gear off and install on the reg. shaft. You will also need the plastic spacer to go in place of the moduale. You will also need bearings on both sides of the shaft now. Sounds complicated, but its not. Self explanitory when you get in there.
shaft http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDLF8
spacer comes with the plastic diff cups
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDLC1
well it looks like your being taken care of but i wanted to take the time to welcome u to the forum!!
