Samrsnow
AKA glue sniffer
- Metairie Louisiana
First off here is what you will need
1: 4 LST shocks
2: 16 washers (4 behind each shock)
3: 8 stock ball ends from the stock shocks
4: 4 screws that are 1/8th of an inch longer than the stock ones that go on the a-arm
Note:make sure you use the little washer that goes behind the the little nut on the front of the shocks backwards.
OK now here is everything
shock,screw,ball joint and washer you will need the same amount as i mentioned above
Now pop the plastic ball joint out of the shock like so
This is what the screw assembly will look like
With the screws in the shocks not you can now put them on!
All done!!
Thanks for looking!!
1: 4 LST shocks
All done!!
