How To Make Battery Packs
fluxinator
I have seen this question all too many times in the chat box and helped numerous people with this. Today I had some spare time and I decided to make a tutorial on how to make battery packs.
The items you will need:
1) Soldering iron
2) Batteries
3) Solder
4) Some wires
5) A male jack for the radio
6) Sand paper
7) Electricians tape or some shrink tubing
8) Soldering skills
9) Time
If you have these things lets continue on to the next step
Step one
Sand off the ports of all of you’re batteries. This removes a layer of oxidation and allows the solder to stick on and makes you’re job lot easier
Step two
Add some solder to the ports of all you’re batteries
Step three
Using some connective media (can be wire or any connective substance) attach the + terminal of one battery to the – terminal of another. For my pack I’m using this lay out OO
OOO
The first two batts.
Third Batt
Fourth one
Then the Fifth
When you have successfully soldered all the terminals you can attach the jack. The + goes to red cable and the – goes to black cable
Then all you have to do is wrap it in elections tape or use a large shrink tube to make a casing for it
And you are DONEEEEEE
Have Fun Bashing It
nice tutorial sudi. but i have one suggestion instead of pretinning the batts pretin the wire. keeps the heat you put to the battery to a minimum less chance of damage to the cell.
where can i find the pigtail and how were the batteries setup? pigtail to which batteries. i am capable of doing this just not sure of how you had the pigtail soldered onto which battery.
can you just use regular aa batteries? i know not rechargeable. if i was to get rechargeable aa batts can you recharge using the same plug type as the roto start battery charger?
started making my own tonight. ran out of solder. doh, will be continued tomorrow. i did find out one thing tho make sure you're hooking up the right battery with the correct polarity, i didn't realize it and when i started to solder one of the wires i was actually shorting out the other battery. i will try and finish it up tomorrow with some fresh batteries
omg got the pack done today and wow huge difference. i actually have brakes now. in fact almost too much, at slow speed the truck does a stoppy lol.
I'm planning on making a few packs my self here soon. I just ordered 12 Sanyo Eneloop NiMH 2000mah rechargeable batteries. These are suppose to be great batteries with very low self discharge rate. Though I wish they had a higher Mah I was happy to find out they had a 1500x charge cycle life and with the low discharge rate they should actually last longer than a higher mah with a higher self discharge rate. My biggest concern right now is not overheating the cell when I solder the leads and connecters on. I also didnt notice until after I bought these that they are 1.2v compared to dry cell AA's that are 1.5v :( this means I need to add one more battery9Now 5 instead of 4) to my receiver pack to make it a 6v pack (I hope they fit). I plan on using deans micro plugs for the leads and wrapping in shrink wrap. Ive also been looking at purchasing the sky LiPo charger which will handle up to 18 cell NiMH packs. its costly upfront to get things setup but i think in the long run I will save money and the hassle of buying new AA's all the time, not to mention saving the environment lol. :jamout:
I have over 20 of these batteries for my transmitters, and here in Norway they cost almost 100$ for 4pcs!!!! But they are wery good. Wouldnt destroy them for making a rx pack i could buy for 40$ :)
But nice tip ;)
Sent from my Ipad
