How to connect Motor wires to ESC
kelles
So i have the mamba monster 2 and the 2350 motor, where do i connect the motor wires on the ESC? I have seen 2 different setups.
Regarding the 2200kv motor with the coloured wires, i have seen some installing the white wire to the middle of the ESC,
but some others are installing it on one of the outer connections and the red wire in the middle.
See 2 photos of the setups below
Which is correct?
Which is correct?
Well I would have to default to what the manufacturer recommends, I know castle has a good helpline so possibly a call is in order
Thanks for the advice, i have already emailed them
Doesn’t matter which way you put the wires in, just reverse any 2 if the motor spins backwards
