how to adjust my brakes
609savage
dirty jerzey
I'm having a problem adjusting my brakes..i don't want them super tight where it don't move but i also want to stop me when at full throttle!!!!!!!!!!!!
replace the spring with fuel tubing on the linkage. then adjust the screw on the edge of the linkage.
You are very limited and will end up with inaccurate results with the stock linkage using the serco saver on it. Most will go to the OFNA style linkage to gain much better adjustability. This mod is also much more consistent. If you search OFNA Mod you will get lots of information. I would post a pict of mine but it will confuse you as its backwords from normal as I am running a Mid tank so my Throttle/Brake servo is in the rear.
I'll help ya out larsenracing. Heres a pic of my ofna linkage.
