Double-O-Zilch
BASHMASTER
- San Antonio, Texas.
I in no way recomend trying to mod an eng yourself. This is what I did and I'm not so sure it was worth it. Shortly after modding my sleeve the front bearing began to leak. After that I went and did the crankshaft anyway. It may have actualy worked had the front bearing not started to leak, won't know for sure till I get it all back together and sealed right. For those who wanted to trade me my engine internals for other things, this is why I declined. It was a sloppy job with the Dremel.
I wasn't sure why I did this other than the idea that less material in the crankcase would yeild more room for the air/fuel mixture. I also exagerated the ports only on the carb side.
I can tell you matching the port to the exhaust port in the block is a bad idea! Not good for the way the pipes are supposed to work. I have tried to mod the stock pipe to remedy this and nothing worked.
Here you can see I knife edged the crank.
This angle shows that I exagerated the scoops on the crank.
The last two pics show that I removed the piston skirt material except for what is needed to insure the sealing of the exhuast. This was an effort to decrease rotating mass.
Getting this engine to warm up takes forever! And then the tune is all over the place. Could be due to the front bearing leaking, not sure though. As you can tell I have no idea what I'm doing and would recommend that unless you do, leave it to the pros as I have had nothing but headaches since doing it. Who knows though, maybe I'll get it back together and she'll run like a champ!
