How do I get my carb to open fully?
xl1
I recently bought a savage xl and I cant open the carb fully? I have not played around with the throttle linkage or any other components. When I give full throttle on the transmiter the carb only opens 3/4 of the way,when I push it with my finger it opens all the way. It seems like the servo does not rotate enough to open the carb fully? Can someone please help me with this problem? Is this a servo adjustment? Throttle linkage? Thanks.
throttle linkage/hpi servo saver. Id suggest a linkage upgrade to get that saver out of the mix...
This is a traxxas mod I did on my Xss
This is OFNA linkage but on my rear mounted servo it works the same from the front.
Search for the ofna linkage mod ... if you cant find it ... i will shoot a pic of mine for you. Also does your radio have end point adjustments ?
