How can i get the rear of my truck to not sag so much
xsavage3148
I tried heavier oil and different pistons but I'm not getting the results i wanted. the back of my truck squats way too much when i give it full throttle.
if you stiffen up the rear shocks, you're going to flip your truck more...the shocks are absorbing the torque during take-off...
if you aren't worried about that, try stiffer springs, and/or adding spacers to the shocks...but get read to buy a wheelie bar if you don't already have one 😀
My truck wont wheelie since i did the extended flm/mugen mid tank setup so i took the wheelie bar off. unfortunately there are no stiffer springs yet for the big bores so i guess i have to wait. i tried more spacers but then the rebound was worse. the truck pretty much touches the ground at full throttle so i wouldn't mind a little stiffer of a spring.
Yes there is different springs.... the longer springs on the big bores are really hellfire springs...:jamout:
ANd then would i have to change oil or pistons to go with the stiffer spring? and how do i tell the stiffness of the spring?
on one end of the spring there is a paint stripe, the big bores come with pink. Pink=Med Soft..... there is a kit for the hellfire that hass all the different springs... i ordered one of the ebay just waiting for it in the mail......
OK i have my white springs now. rebound is still not how i want it. if i want faster rebound should i switch from the 1.6 piston to say the stock white one with the same 35 oil?
OK i swapped the pistons back to the white ones with same 35wt oil. with white springs. rebound isnt as fast as i would like but i think it might be good enough. i have to run the truck to really see how much the *** sags at full throttle. I'm just working on the hellfire shock mounts now.
