Hey I'm just wondering is there a way to get it out without taking the whole out Thanks -SalOne Way Bearing. It's in the back plate. It allows the engine to be started. Assuming you're using the "Roto-Start" it's the part that makes it grab the crankshaft (doesn't actually attach to the crank, but works for this description ) but spins when turned the other way, allowing get the engine to spin freely.
They get oil (fuel) leaked onto them and they slip on the shaft.
Hi It did it again and now this time it dosent spin even with the glow plug out do you know what happendOne Way Bearing. It's in the back plate. It allows the engine to be started. Assuming you're using the "Roto-Start" it's the part that makes it grab the crankshaft (doesn't actually attach to the crank, but works for this description ) but spins when turned the other way, allowing get the engine to spin freely.
Never mind I found out what I was I need to buy a new roto start bearing
Do you have any suggestions on how to get it started I know that the fuel and glow plugs are good and so is the tune I think I need to just spin a little bit more to start uptrying to start an engine that just does not want to run usually results in overheating the OWB and causing this very failure....
Thanks for the info I prime it by blowing on the exhaust gas line I'm thinking about getting a pull start because I've burned about 2 of the owb's with the roto start what will be better roto or pullwell usually a well tuned engine will start within the first few revolutions of the wand, are you priming it before trying to start ? also you can add a bit of air by just opening the throttle a bit on the trigger...
I would highly recommend to get very familiar with which adjustment does what and practice until they become second nature...
Also a read through this thread may help you get a better understanding of when and how to do all the things necessary to have an enjoyable day...
https://www.hpisavageforum.com/threads/the-complete-beginners-guide-to-rcs.814/
Thanks but how do you prime your truckswell roto or pullstart is a user preference, I do not like blisters on my hands and have bad wrists and shoulders so I use roto type starters on everything I have, my rigs usually start right off and usually don't require many adjustments so i hardly ever destroy a one way bearing......
Witch one would not melt the OWB as fastwell roto or pullstart is a user preference, I do not like blisters on my hands and have bad wrists and shoulders so I use roto type starters on everything I have, my rigs usually start right off and usually don't require many adjustments so i hardly ever destroy a one way bearing......
Witch one will not melt the OWB as quick roto or pullHold a finger over the exhaust port on the end of the pipe with the igniter off run the roto a second or 2, usually 3 turns is enough to get fuel to the carb..... then put on your charged igniter and fire up the
having a stand of some sort to keep the wheels off the ground is the best way to start your rig up...
I made one out of some scrap 2x4 material and it works pretty well
