hex hub wheel extensions?
destructive
Do any of you guys use these? do they work good? what are the negatives? will i still be able to wheelie? trying to turn harder at faster speeds without the barrel roll effect.
i haven't got them but i think it would be easyer to snap your wheels off if you crashed or did big jumps and if you turn normally your turning radius will be bigger. If you want to turn more at fast speeds you could also lower the center of gravity in you truck. and also an extended chasis if you haven't allready got one.
hope this helps
4x4
my truck is pretty stock except for the engine, pipe, tvps, and - a arms. I'm even thinking about going back to stock plastic a arms. do they make extended a arms for the savage? maybe ill just do that and some goliath tires
