Help!
PandaZmaj
Serbia/Denmark
Hey ppl ??
Can someone help me with info what kind of lubricant need to be used for transmission
Tnx ?
Hey ppl ??
Tnx ?
I believe you should leave the transmission alone. Just make sure it’s dry. You do however need to put diff oil inside the diff. There are different weights which make the car behave different. I also put grease on the diff gears. I use Lucas red and tacky, white lithium grease should work. Tons of options. I’m not an expert, so hopefully someone will chime in if I’m wrong, but hope that helps.
Hey ppl ??
Tnx ?
If it's a nitro 2 or 3 speed, don't put anything inside the case. No lubricant or it will interfer with the shift clutches. Now if it's a flux, I can't comment cuz I don't have one, but I don't think any lubricant is used in that either unless you have a center differential, which would need diff oil.
