ShiftPoint
- Ft. Laduredale, FL
Hi,
I took my truck u for a test run after installing nova shoes,, neww fuel line, and cleaning up my Buku and installing a 1 peice header.
I have a stock K4.6 and have never had any problems with it, today after doing the work above on it I took it out and at first while getting up to temp maybe 160 or so it bogged down for a second, then it was running like a bat out of h311, running better than ever. Oh I also recently adjusted my 1-2 shift point, not 100% sure it is correct. but after about 1/2 tank it bogged and died on me, I restarted it , and it started easy, but when I took off it was going very slow, the motor was like bogging or running at low rpm's and a deep sound, as I was bringing it back toward me it oied again. at this point It is too dark so I came in and came to you guys for help
I haven't looked at anything yet, but the fuel line I might be suspecting, it is a bit smaller dia than the stock, don't know which to order, but I am not sure it is enough to cause what it did.
any ideas?
any ideas?
