Hello! New Savage XL Octane owner in Iceland!
Okay. Well I did as you two said, I turned the idle screw clockwise, so it'd run a bit faster and I turned the low speed needle half an hour clockwise, maybe a full hour, not quite sure. It started up .. kinda hastily but once I gave it two good up and down the parking lot I was in, it was running good and I could lower the throttle trim. I noticed it choking when flat-out throttle, so I leaned the high speed needle until it didn't do that anymore, and it was quite powerful. I found a dry pavement with no snow on it, got the front tires just a tiny bit off the ground. I'm noticing the steering difficulties that Gaj pointed out, so I'll probably try to mount the old, stock tires to the new rims that currently are being used with the shovel tires. Sorry for the walls of text, and thanks for reading them. 😀
  • Like
Reactions: GAJ
Hilmaar,
The front and rear wheels will want to spin at the same RPM resulting in the smaller tires continually being dragged along the ground. You need to make the change, you are probably damaging your drivetrain.
Hilmaar,
I did not realize that, thank you. I will not drive it any further without proper tires.
Edit: Just wondering, why does your forum proxy images posted? 😵
Because we use an SSL certificate or HTTPS here, in order for each page to remain secure and HTTPS this has to be done. Otherwise when a member posts a picture from outside of HPISF everyone would get mix content warnings in their browser. 😉
Change or clean the sparkplug. Also are you having a problem trying to pull start it? And the Octane takes about 10 tanks before it starts shifting gears.
If your car is new and not broken in, you need to carefully break it in, it's important.
If it starts and dies, first check that the battery is fully charged, if it is, try swapping for a new spark plug. Get 2 extras right away if you have none.
If the car runs for a while with a new spark plug, and you then end up with the same behavior. Swap back to the first one and try again.
Do not run the car much more than idle speed, or the speed needed to keep it running, not more than half throttle though, until the car is running fine and not dying every now and then. It might take 2-3 tanks (or even more). During this time, you'll be frustrated with the car stopping all the time. Just keep swapping between the spark plugs and keep it going. During these first 2-3 tanks, just take off the wheels, put the car on a stand, and let it run. When it runs fine for a whole tank, take it out and run it on the street for a tank or two to make sure it is running fine. Adjust the "throttle pusher" on the servo linkage so that full speed on your transmitter whil give only half throttle on the carburettor, just to make sure not pushing the car until fully broken in. After 1-2 more tanks, your car should be running fine and now, not before now, you can start fiddling with engine and gearbox tuning. Run stock settings for the whole break-in period. Do not run high rpm's during break in.
If the car is still not running ok after 4-5 tanks with the above procedure, or even worse. Take it back to the store and require they swap the piston, sleeve and piston ring. Simpy because, in my opinion, HPI has a compression issue as a result of poor manufacturing specs with these engines. Some will just never "break in" properly and give the compression required.
I tried and tried and tried everything trying to get mine to run, in the end I realised the pull started was way to easy to pull, which indicated no compression, so I got the tools and measured in, there was no compression. HPI refused to help out or replace the parts needed, so I had to by new ones my self. I have since gone through the process mentioned above, finalizing it today, my kids just ran the 6th tank earlier this evening, and the car ran from first start until empty tank without one single stop. Oh, it was raining outside and the batterybox had some water in it. Ballons may be a good idea 😉
I did have the problems and frustration mentioned. Be careful, keep stock settings, use charged batteries and keep swapping between 2 or 3 spark plugs, and you should be fine in the end. 🙂
Ok, just saw the last couple of posts (why didn't I see them before?)
In any case, you just might have to swap spark plugs several times for the first couple of tanks, trying to keep the engine running.
It worked for me, (and I have some ideas on why it might be like this, but thats for another long post some other day 😉 ), it'll probably work for you too. Though it is frustrating, it is also releaving to see the engine actually starting again after swapping the plug. Just bare with it for a few tanks, and it'll sort itself out 😉
