header tank can eliminate the half tank lean issue?
The engine is leaking air would be most likely then.
First - check it for air leaks then fix them with a sealant. Possibility's of places leaking are the back plate, carb to block, carb needles, a crack in the block (typically caused from loose motor mount screws).
