Having trouble setting the carb
Allan
Good day.I have a savage .21 3.5 green Jeep.Me and my son have very much difficulty to set the carb.It still don't want to run proper. I must play with the petrol otherwise it die. The motor also run very hot but there is smoke coming out. They said I must use 25 %.I thought about stripping all nitro out that is how down I feel. I did clean the carb.What is wrong and what must I do please. Thank you all. Have a blessed day.
Regards
Allan
Perhaps you have an air leak. You can pull your fuel tank and fuel lines out and stick them under water, then blow through them. If you see air bubbles, you've got a leak. You can also try sealing your engine, THIS thread will instruct you for that.
Might want to check your header gasket as well. They have a tendency to get chewed up, then you lose exhaust pressure to push fuel into the tank and get improper 2-cycle pulsing from the pipe as it's running.
