Ok guys yet another odd mod for Jt
We are going to tackle CEN GST diffs, and modding them to be run in a savage truck. I have done one set for myself but I will be showing what I have done for Site Jester, the local "Diff Stripper"
First lets see the CEN diff
Lets see 2 diffs totally tore down.
Some comparisons next to the Savage diff parts
out drives and pins, the Savage out drive cups need to be drilled out for the bigger CEN pin, because the CEN out drive is to short the dog bone could fall out if you used the CEN out drive cups
pinions
Ring and bevel gear
Spider bevel gears
The CEN bearing are metal shielded, we will use some rubber sealed bearing when we assemble the diff, here is also a center portion compared to a nova cup.
The spider bevel gears lightly greased on the back side to hold them to the block for assembly into the cup.
center sections 1 ring ring gear installed and the other with end cap installed
blocks and spider bevel gears installed into center sections
filled with oil
2 complete diff assemblies
the amount of shimming I used to fit the pinion for proper mesh to the ring gear in the "X" style diff housing
I couldn't get a real good pic but here is the diff in the housing meshed with the pinion
the savage pinion cup fits just fine on the CEN pinion you will need to grind off the pin portion of the screw off or if you have a plain grub screw that works just as well
here is the pinion cup attached to the pinion and the diff is ready for use as soon as the ring and pinion are greased
Enjoy Site Jester, lets see if you can make these last longer than a day. :stickspank:
pinions
Ring and bevel gear
Spider bevel gears
filled with oil
