Gotta rebuild 32 spec
jackel
ocala fla
Well the axail turned out to be a good mill i have 8 hard!!!! gal in her then last weeekend my father in law were playin on our track he hits me with his bajha knocks off the air filter of course i didnt see it come off chasin a 5b with no filter tends to make a nitro to shut down. :stickspank:
CHECK OUT THE DEAL SMF HAS
Axial Piston/Sleeve Set for .32 Engine - #043
[AXI043]$43.99
In Stock
This is the factory replacement piston/sleeve set for the Axial .32 engine.
well guys rebuilt the 32 spec the parts took to long to get heare but it turned out well yes polished the crank that turned out very nice good build for a nubie that wants to get his feet wet. let ya know how it runs. yea i fired it
you want worn out? i have a 3.3 piston that i had for 2 years. i ran about 15 gal through it . yes 15. when i eventually had to replace the piston/sleve/rod last month i found that with the engine disassembled the piston can push completely through the top of the sleve. you think its easy ? you try to do it. i now know why it would'nt start last time i had to run it. now that its been rebuilt bring on another two years.
