going xl lets make sure i get it all!!!!!
i got the xl plates..motor plate and xl dog bones..anything else i need:loveford:
If you have the dogbones you will also need the super heavy duty diff out drives and axles (Flux or XL extended axles, your choice)
Do you have the XL length centre rear dogbone too?
your gonna need these http://cgi.ebay.com/ws/eBayISAPI.dl...fc7c05f&itemid=310202676428&ff4=263602_263622 the cross bars with the notches in them so the dogbone works.
You can also use a half round or rat tail file to file out the notches like I did on my I-RC one piece plate/braces lol
Yeah I got a plate that comes with those bars cut already... am going to need dif cups as well?? 2 of them??? From the tranny back??and do I have to get extended axles ????what if I want to make it wider also what do I need for that??
do I am going toners dif cups as well?? 2 of them???
Sorry I don't understand what you mean?
You say you have XL dogbones, which ones exactly? 4x outdrives or a centre rear? Or both?
You don't need to change the centre cups, the XL centre rear bone will fit into the cups you have already. XL centre front bone is standard length.
If you want to widen your truck you can use XL extended axles but you will also need XL/Flux diff outdrive cups and dogbones or you can use offset rims.
sorry midnight sleepy post up there lol...so i don't need diff cups for center dog bone....sweet.......so if i want it wider... i need
4 xl bones
4 extended axles
4 dif cup for f&r in total
so i can use my stock arms???
4 xl bones
4 extended axles
Bang on mate!
Just make sure the 4 diff cups are the outdrive not centres and are super heavy duty version (standard on Flux and XL)
You can use Flux or XL dogbones (they're the same)
Its only the axles that differ between XL and Flux, XL ones being extended and Flux are standard length.
Yep stock arms all the way, the extension is in the axle not the arms.
Hit back if you need any part numbers, or need to confirm your gettin the right thing before you buy 😉
