Well first off what is the weather like where you are? and what engine?
If its really cold outside use a mcCOY mc59 plug.
Not till spring eh? What engine do you have? please tell.
well just as a example in the summer months here in canada i run a MED-COLD (R4) outside temps are about 70-95 degrees and my engine runs consistantly at 230-240 dgrees
OK so it seems like I should run a med/hot plug. Going to wait until spring to run my truck. Again going to run 20% sidewinder fuel and I have the stock K4.6 motor. So is it safe to say that in the dead of summer when the temps are around 85 - 90 degrees outside I should be running that med/hot plug? Also I understand that some plugs are different lengths which length do I use a short or long plug? I think they were the long ones, I kinda forgot which one I used in the past I believe they were O'donnell plugs. I understand that dsifferent lengths can effect your tune/compression.
Yes that was the answer I was looking for. I guess I should have asked what plug do I use for cooler temps say 50-65 degrees and which ones for temps in the upper 80's and 90's. LoL So MC59 when the weather is cool and MC9 when the weather is hotter Might just use the stock plug during break in.
Can anyone please tell me the difference between these plugs MC-8 Medium Hot #8 and MC-55 Medium Hot They both say Medium Hot.
No problem. Just glad I was able to help. Some little tips to remember. Higher % nitro-use a colder plug. colder outside air temps, use a hotter plug.
Sorry but had another question. I'm looking on horizon site and noticed that there were two types of Mccoy plugs. One was a power plug MC-59 and the other said MC-59 (NOT POWER PLUG) The power plug is made by Dynamite. Are they different? Or are they both long plugs.
I'm not sure about the dynamite plug. Are you gonna be ordering them online? Here are some links to the McCoy plugs on Tower Hobbies website.
MC-59
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRA06&P=ML
MC-8
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRA02&P=ML
MC-9
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRA03&P=ML
Maybe this will help you out. I order stuff from Tower when I can't get it locally and they are real good. And prices aren't bad either.
No Problem. Any other questions you may have, feel free to ask away.
OK here it goes. I want to get a set of extra clutch shoes for my savage. Should I go with the HPI set. http://www.hpiracing.com/products/en/87196/
Or do you have a different set in mind.
The HPI alum. shoes aren't that bad, but they're cheaper ones out there that work just as well as the HPI alum. shoes. I personally, am switching to a sliding clutch once I get the money. It all depends on what your're lookin for.
Ya I think I'll go with the 1.0 springs. I have 1.1mm mugen springs. What type of shoes should I use with those springs?
