Gear combinations
JKLNHYDE
Does anyone have a more complete gear chart showing all the possible gear combinations rather than just 49T and 52T Spur Gears???
Reason I ask is because there are more combinations available but may not necessarily work because they won't mesh exactly right.
The genaric chart I found on here shows specifically that a 13 and 14 Clutch Bell WON'T work with a 49T Spur Gear. What Clutch Bells won't work with a 47T, 50, 51, etc...?
Tried searching to find my answer but nothing so far...
Thanks!
Scott
All the gears will mesh properly if you can move the motor far enough to the right or left. The clutch bell and spur gears all have the same pitch to the teeth. What limits you is the motor position. Some people use a dremel to modify the motor mount holes so the motor can move a little farther to the right or left to allow them to get proper mesh. I don't have a list for that, nor have I experimented with really extreme gearing one way or the other, but I know you can make things work with a small amount of dremeling even if a chart tells you they won't work with the stock setup.
MikeK1981,
This is precisely the overall answer I was looking for! Thanks!
