AoD
- Hammondsville, Ohio
As some of you all know I recently had a bad crash that ended my steering servo's life. The crash stalled the motor on impact.
I got it all back together, and filled the tank. I started it (started extremely easy like normal) and ran alright for the first half of the tank. I run rich settings for account of the half tank lean problem.
Now, it eats the tank in about five minutes, won't go to full RPM, and it seems like it's just running rich as the first half of the tank usually does. I mean, it still runs decently strong. It's almost like there's a fuel leak, but I can't find one for the life of me.
Now, here's the problem. Even when I lean it out, it doesn't seem to have any effect what-so-ever. I turned the needle in almost 3 turns, and it's still running rich. I'm at a loss, as I haven't ever seen this happen.
I did the airleak test with the motor on the chassis, and I really don't want to have to pull the thing apart again lol I didn't show any leaks on either the fuel tank side, or the motor. It's got a TON of compression, and I can't turn the flywheel by hand unless I hold it for a while and let the compression release over time. It's got a new glow plug in it, and I'm still having trouble. I broke the end of my pipe, and tried another; Nothing.
I'm at a total loss here, don't know what the heck is wrong.
