300m
Alright guys, ive got 8 nitro engines i wouldnt mind getting rid of.
7 big blocks and 1 small block.
I am not 100% sure on any of these engines, i do not know if they work.
All of them but 1 turn over smoothely. All of them have excellent compression sitting here on my bench. Not sure if there are any problems with them once they get up to operating temp. I have visually looked over a few of the engines that i had my doubts in. Ive taken a few apart and looked them over and seen nothing obviously wrong with them.
I am not able to fire up any of these engines.
These are all being sold as is.
First up is a pair of Mach .26's.
One of them looks nearly brand new, still has the sticker residue left on the cooling head. The other is definitely used.
Both have OWBs, Both need pull starts.
Asking $65 shipped for the newer of the two and $45 shipped for the other.
Next on the list is a Dynamite .19. This engine looks pretty good. It is also used. I'm including a spare stock cooling head. Am asking $40 shipped for this engine
I have also got a Dynamite Platinum .28XP, this engine needs a set of bearings put in it, the rear bearing is rough and nearly frozen. The piston and sleeve look nearly brand new. This engine is set up to be run with a starter box. Asking $55 shipped
Next up in a Novarossi R21. Visually i see nothing wrong with this engine, it is missing the arm on the carb slide to set up a linkage. There are a few knicks on the crank where the CB rides, however they are smoothe and should not cause problems with CB bearings. Asking $75 shipped
I also have a Losi 350. This engine looks to be in great shape. Set up for a starter box, needs nothing that i can see. Cooling head is fresh and not scratched or banged up. Asking $65 shipped
And then i also have a Dynamite Platinum .21. Scratched a knicked up but has good compression here on my bench. I see nothing wrong visually with it. Asking $55 shipped
And last up is a Losi 454. This engine looks like it is nearly brand new. The cooling head is scratched up a small amount. The crank case needs to be replaced. Looks like this engine landed upside down, crank case is cracked
near the left engine mount. SOLD
All of these engines are sold as is.
Like i said, i can not test them as i do not have the equipment or supplies
to do so. I will combine and sicount prices if you want a couple engines, i will also sell all of them together at a discounted price. I simply want these out of sight and in the hands of someone who can use them.
I take Paypal and Money Orders
Prefer Money Orders but Paypal works alright.
Thanks
-Sean
Thanks
-Sean
