Front Alignment
McF
Just built X SS and noticed that my front wheels aren't quite right. If I align one front with the rear,the other front is kicked out. My steering rods are 44mm. I have disassembled and reassembled this to the point where I just can't get it.
What gives?
Thanks
If you adjust the Toe angle, it will change the camber because of the positioning of the ball. If it were in the center of the (can't remember part name) then it wouldn't be noticeable.
Align the tires so they point straight forward, that should fix your camber issue.
As for how much camber is too much, I have no idea, does anybody else?
