Flux questions ?
DGCON
Been reading up on the flux , taxes coming soon :)
Does the flux come with bulletproof diffs ?
( It just says super HD on the tower site )
What weight oil is in the big bore shocks ?
What weight oil for a Tcs XL ?
( Big jumps and bashing )
Thanx for any info
Also what type of battery connector does the flux come with ?
battery connections are deans, and the new flux comes with bp diffs. i think the oil that hpi uses is equivalent to a 10wt silicon, but theirs is just a normal oil. for the TCS chassis i'd use 35wt, any higher and it seems shafts bend.
Cool , Thanx 88gtanotchback
I've been reading on batteries as well 4s and 6s , from what I've read 4s is easier on the esc and motor. I'd like to be in the 45 - 50mph range. Any gearing recommendations ?
stock gearing and 4s is a great safe combo and should get you 40mph plus. just get at least a 125amp combo. ie. 5000mah 25c packs. (5x25=125amp) although it would be better to go higher yet if the budget allows.
I'm looking at MaxAmps XL9000 7.4v
Hyperion charger and power source
Castle programmer
Been online all day LOL
I also read that they're are a lot of other battery options but I like the warranty and run max amp receiver packs in all my nitros
