I was under the impression using less toe in the rear helped it go straighter at and faster? I can see how acceleration is affected more toe in allows the rear to follow the front coming out of a curve, but as for going straight and fast. you reduce the rear toe? As we know the traction is what causes this truck to flip over so muchMost of the trucks use about 3 degrees of rear toe, it helps keep it somewhat stable at higher speeds
What sort of setup to you run Jam
