chronic
I'm having some troubles with this thing. Ever since I had to replace my front bearing its been a night mare just finding one. hobby stores around me are useless and tell me my only option is buying a crank case with new bearings... With the money I've spent on bearings, I should have just done that.
But I'm just wondering, does any one know if k4.6 front crank bearing will fit? I found a bearing from losi that looked almost identical, same specs. Fit my crank and crank case. Had the rubber seal on one side instead of just a steel washer. Then I reused the brass reinforced rubber seal on the outside and it still leaks. I can't find those rubber seals seperate...
If I install the bearings with their rubber seal on the outside, will that work? I've only been putting these bearing into my engine with their seals towards the inside because thats how my stock one came out. Then it had another seperate seal on the outside.
Stupid f engine, no body has replacement parts around me. Hense me buying a used k for a spare I can actually fix lol.
I hope thats not chinese. And you can actually understand it. You guys are the gurus. LHS people are ... not helpful and only making my life harder with half the crap I've been told.
One guy told me not to use air filter oil with any filter. It restricts horsepower... He says
This same guy didn't know what a crank shaft was for...ohhh man! Just a little FnF for you, fun fact for the night.
