Update on F4.1 inner crank bearing, I found the following bearing is an exact fit for the F4.1 Inner crank bearing.
https://www.ebay.com/sch/i.html?_fr...XO.S.23930000.TRS0&_nkw=O.S.23930000&_sacat=0
Still waiting to hear from HPI they were going to contact FORCE engines as FORCE wouldn't respond to my Emails.
HPI Response -
[email protected]>
Sent: Thursday, April 19, 2018 12:59 AM
To: Wayne ----------
Subject: RE: F4.1
Good Morning,
I have just been to see the products department. They have said to me it would be more beneficial to contact a bearing supplier as these bearings will no longer be manufactured for ourselves.
One of the guys is on the Savage Forum so I have mentioned your post so he may even respond to you through that channel.
Kind Regards
Josh Nixon
Customer Service Technician
FORCE Finally got back to me , Gave them Engine info. and picks of F4.1 , Hopefully the have a Bearing for F4.1 for others out there besides the High priced an very limited ones on EBAY.
FORCE RESPONDED,
4/24/18-
For the request parts of HPI F4.1 engine (.25) , our code # is B003 bearing 13x24x6mm , #
CS2108T SG shaft 13mm .
Best Regards.,
Joy Chen
Force Models Co., Ltd.
Did put F4.1 back together with ALL New- Crank Bearings Front and Rear, Piston / Sleeve , Con-Rod and Piston pin, Used the seal it ALL up method that "X" put up in Nitro Engine Sealing and Olds97 Lss found picks for. This is the only way to go Even for a new engine right out of the box . Also put some Anti-Seize on sleeve .
