Hankinator
I was tired of splitting my savage to adjust the 1st-2nd gear in my 3 speed tranny. I know an X style easy access case is available but this still seems like a significant amount of work.
So I made 1st-2nd externally adjustable….Heres how.
Disassembled the tranny (last time I hope) and removed second gear as the adjustment is “insideâ€.
Drilled a hole through the gear…like this.
The adjustor is offset so the access hole in the gear has to be drilled AND angled.
Marked and drilled the case for the outside access hole.
Cleaned, lightly lubed and reassembled.
Notes: The gear is hardened…not easy to drill at all. Have a couple of bits. I could easily see a drill bit breaking. A drill press is highly recommended.
Obviously putting a hole where there shouldn’t be one weakens the gear. As hard has this gear is and the contact patch/mesh I don’t anticipate any durability issues but I will surely bash test and post if it breaks.
I will follow up once I run.
