ESC setup question
Promc
Turns on a 5p!
Evening guys,
I got the new esc through from hpi,but am having a problem setting it up 🙁.
I reconnected all of the wires where they should be (A-A,B-B,C-C etc) ,reconnected the receiver wires,then turned it on for the first time whilst holding the throttle,but all i got was 3 beeps then a constant green flashing light with no beeps,instead of "2 short series of tones followed by a 2 second pause,followed by a long series of tones".
Am new to electric,so started checking the wires were in properly etc,all were in properly.Whilst the truck was on,i thought i would try taking the steering/throttle wires out,one at a time,to see if this would make any difference.As soon as i took the throttle wire out,the truck started beeping straight away(cant remember what the lights were doing).
So i put the wire back in & it went quiet again,with the green light flashing.
Am running a spektrum setup,but tried it with the hpi tx/rx & it did the same thing.
Any suggestions:Xfingers:
😛eace:
Promc
Oh yeh and if that works and the motor turns backwards when u hit forward swap two wires on the esc to the motor
