I have a Savage X 4.6 using Roto Start to start engine. I set the throttle to 1/2 open with the trim on the controller for starting. I prim the engine by putting finger over pipe opening and running Roto start until fuel reaches the carb. The engine usually starts right off but revs out of control for 15 - 30 secs. then settles down and I can adjust the trim down to idle on the controller and it seems to run fine after, I am concerned the over reving will damage the engine or the drive train as the wheels are spinning like crazy.
Not sure what is causing this. The throttle control does not move. The low speed needle is flush . The high speed is in one full turn .
