Engine Heater.
Chris Down
Started easily. But how do you use it. Do you connect it to a LiPo battery, put it over the engine and leave. Don’t want to break it!
thanks in advance.
chris.
Can’t recommend these enough helps get that tight new engine started with ease, even got my old Picco engine which was last used 14yrs ago running again!
You can run it off a 12v gel battery or a LiPo battery (both of which Model sport stock) I believe, I just power mine off a 12v gel battery as I already had this & charger which I run my glow starter off!
Just press the white button & turns itself off after 10 mins or just press again to extend it further! ??
