Electronics HELP
kvnnets
Oakville, Ontario, Canada
OK. So I'm doing the mid tank mod and have a few questions.
Where should I put the wire that is used to charge the hump pack. Don't want to leave it exposed. It gets wet, dirty, etc.
Second question. Can someone show me through some pics how to mount the receiver in the RPM box along with the ON/Off switch.
Any tips would help a great deal.
Not sure about where to mount your charge lead, i don't use one but this is how i did my RPM box with Rx and switch.
The reciever was a fairly close fit in there but i used a bit of double sided foam to hold it there anyway.
For the antenna mount i used the mount from the stock radio tray, cut off and CA'd into a drilled hole in the box.
I stuffed it all in there too but I cant find a pic. I took out the jack and plugged the hole a long time ago after seeing freds pic right there. My battery connection is beside the tank for easy access to it. Just tossed in a servo extension to get it up there...
