EHL 6s esc
1BMFNJ
For some reason, my ESC will only set neutral & full throttle. It won't beep 3 times at all. I've tried everything. It worked fine in previous build. Any thoughts?
JCD
Hi, it is my understanding the XL flux ESC is a rebranded Hobbywing QuicRun 150a ESC. This link to the manual.
http://www.hobbywing.com/products/enpdf/QuicRunWP10BL30-10BL60-8BL150.pdf
Keep in mind the ESC from HPI and other like redact kaiju, rofunracing.com (torland XL) use the Ready To Run ESC version of the
QUICRUN 08 (WP-8BL150 V2 CTP)​
Keep in mind the RTR Only has 5 settings you can change with a program card as to the non ready to run version which has 12 option.
Hope this helps.
1BMFNJ
Hope this helps.
I've tried to use my programmer as well. Didn't work. Set the ESC back to default via manual instructions & the same result. 1beep (N) set, 2beeps (FT) set, then I apply FB & no flashes/beeps.
olds97_lss
HPISF Supporter
Dekalb, IL 60115
Are your throttle EPA's both set to 100% for forward and brake? I had issues setting one of mine up because I had adjusted the remote to 40% for reverse (vs changing it in the esc), then it didn't want to calibrate. After setting the transmitter back to 100%/100% on forward/brake, then I was able to recalibrate it.
