E-Savage/E-Zilla 10 Shaft upgrades
boostjunkeee
Hello,
I have an all original E-Zilla 10 apart from the 3racing alloy shocks. Even all the electronics are original and working. I'm waiting on some new batteries and receiver to connect to my futaba.
I have read that the shafts are weak and i can see they are plastic and that T-maxx/E-maxx shafts fit and are stronger. But I'm having trouble trying to find the correct part number of these shafts, any ideas or other options to try?
Sparky
The stock traxxas tmaxx driveshafts will fit the 4 outer driveshafts that go to the wheels,
But you have to use your stock hpi e savage ends
They are a direct fit other than that and a good bit stronger than the hpi shafts
boostjunkeee
Ok so stock plastic t maxx outer shafts slide over original e savage inner shafts correct? And do you mean i need to use original e savage wheel stub axleand joint onto to the t maxx shaft?
Sparky
No,
You use the complete tmaxx shaft,
You just have to fit the e savage stub axle to the ends of the tmaxx shafts,
And also the end that fits onto the diff side of the shaft,
Tharper82
Boost did you ever get the axles and try them out? I found my old e savage and it has broke shafts and I'm trying to find something to fix them with.
