Great pointsYes. The engine will still run fine in the cold depending on how its tuned. HOWEVER the engine will most likely run much cooler than what it was intended to and cause a lot more wear on the piston and sleeve. ALSO make absolutely sure that your electronics are waterproof. Get waterproof servos and make sure the receiver is sealed up very tight. And blow the snow off of it when you're done. Runaways do happen because of water
I do!! Just be mindful of the electronics. Waterproof receiver and servos come in handy as well. Bash away!!!Can I drive my nitro savage in the snow?
