Divey1130
Well, I'm going to start this thread for my mid tank mod and the other mods I plan on doing. I figured I'd keep it all on one thread to minimize the clutter. Still waiting for most of my parts. I did receive my hitech 645mg servo for the throttle/brake and my bulletproof diffs for front and rear. I plan on doing the mid tank mod with the Ofna tank, the ofna throttle/brake relocate mod, and a skid plate mod. I have already shaved the hubs for steering and wow does it make a difference and the trimming of the servo saver on the throttle/brake servo and that made a huge difference with the braking. So to begin my journey I started the skid plate using 2mm flat sheet alum. I did have 4mm but it looked to big for the job and the 2mm will do just fine.
Skid Plate Mod:
I started out by cutting a piece at 3 3/8 wide by 12" long. Measured the distance to the bend then slightly scored the backside to get a perfect straight bend. Man let me tell ya, it is a pain in the butt to cut it using a dremel but it worked out. Then I put a slight bend into it and test fitted it. Then I beveled the ends to match up with the existing plastic skid plate. Cut to length on both ends and used a file to smooth out the edges. There is one slight spot right under the tranny where it touches so I will cut some kind of design out for that clearance and also to give it some definition. Here are a couple a pics so far. Tomorrow I will cut the center out and try to get it to some what of a polish look to it.
Skid Plate Mod:
