Savage89
- New Jersey
I shattered my diff gears twice in the past week what would be the best possible solution?
hey there ... how are they getting chewd? is it the pinion gear that rubs the outer ring gear? or is it actualy the inner bevel gears? and what set up are they? 2 gear or the newer 4 gear set up..witch is actualy 6 gears lol.. ..are the bearings still nice and tight? might need shimmed...i can help you but need a lil more info on what truck it is ... do you jump it and land with wot .. is it the front going out or the back? ect ect.... let me know ...tc good luck happy bashn..
i hear ya on the tired of takeing apart and putting it back together again .. gets old ..you said its the rear and you run on pavement ... bearings still good... what engine you running? some like the picco or lrp are power houses they eat diffs up.. but are you sure the bulk head and diff cups still in good condition? are the gears fitting together realy tight but smooth? any slop in them with a decent mill. will eat them up on pavement... you might need to shim the diffs to get a closer fit.
heres 1 of many how to shim your diff threads on here ..https://www.hpisavageforum.com/forums/showthread.php?t=9865&highlight=shimming+diffs
I'm thinking its just got a lil slop in it or the housing itself is not perfect any more... good luck i hope this helps ... happy bashn...
the .28's have more power the anything bigger. and yes you can switch to the "x" bulkheads and anything thats on a savage will go on any savage. to me it sounds like the bulkheads are suffering from severe flex from the torque and that will eat any diff apart.
let go of the throttle before you land :stickspank:
I would if I jumped this truck
