Diff&pinion ?
ROCKO9865
First I Was Wondering If Anyone Shims There Pinion? If So What Size Shim Do You Use? Since I Broke Mine A Couple Of Days Ago! So I Ordered The Hardened Metal Gears For Mine And Was Wondering If I Should Shim It Or Not. I Know It Helps On The Mgt. Second I Was Wondering What Diff Oil Wheight I Should Use For Bashing Not Raceing.
You can and should be able to use the same shims from the MGT. For bashing I would run something like 50,000wt oil in the diffs and defiantly shim them or you will be replacing them again.
Again welcome aboard and we are glad to have ya be part of the forum. Look forward to seeing you around.
thanks for the info. i figured it would be good to shim them. Its cool that you can count on this forum for expert advise!!
