ohsnap
- Location
- North Carolina
I run a variety of parts on several Savages, and when I originally installed CVD;s it was first to replace a dogbone that broke, and I'm willing to admit that the thought "hey, these are an upgrade - they must be better" probably crossed my mind to justify the cost.
Looking back, CVD's are currently my most consistent failure point, and that being the pin backing out.
And yes, I am familiar with the concepts of thread-lock and prep...
90% of the time, the grub is tight. 10% of the failures are probably on me.
I've run Hot Bodies, MIP, and even titanium ones.
I have some CVD's that never give me a problem.
The TI's were by far the worst.
With the TI's, it wasn't a question of whether or not that the pin would back out, but when.
I had one Savage with them down the centerline and out to the four corners.
Both the front and center drive ones were the worst.
At one point I HAD to deal with one of them and under the circumstances - both, every week, but eventually one of corners would also let go.
Yanked them all out.
As a general trend, regardless of manufacturer, the front and center CVDs seem to be the worst offenders.
I replaced an old Hot Bodies CVD that went bad on me earlier this year. I noticed that the slot in which the pin rode was worn so that it was more "S" shaped than parallel.
Given how the pin interacts with that slot, I can see how it screwed itself out of position.
The only fix was to replace the worn part (or in this case the while unit).
I couldn't get two tanks through it before the pin was wedged under the motor mount plate and locked things up.
I have also noticed that the pins in the newer MIP rebuild kits are notched out in the center, while their older pins are not.
I don't seem to have this issue with the CVD's on other trucks like Revos or Hellfires.
Now watch, they'll act up.
I did have to replace a right front dogbone in the past year, but its demise given the hit is understandable.
It snapped, but it was also older than dirt...
Thoughts, tricks, opinions?
What do you run and why?
