I am just finishing up putting my new truck together, I have the 17t vented clutch bell and the 'thin' 47t steel spur which I believe are those supplied with the X SS kit (my truck is a scratch build and I have had parts from all over).
I have a few questions!
First up, from searching on here, plastic spur seems to be favoured. I can understand it's better to have a cheap weak point and it makes you set a good mesh. So why are HPI supplying steel spurs now with the X SS and XL? Is it just to help with noobs destroying spurs or are they required for more powerful engines available now?
Which brings me on to my next question - is it not advisable to run a hardened clutch bell with steel spur gears? The clutch bell HPI are supplying with these steel spurs are AFAIK just standard vented bells. I mean, I'm sure HPI know what they are doing and all but it seems a little odd in the face of all the advice I have seen?
Finally, having fitted said steel spur for into my truck I notice there is a certain amount of play/wobble as it rotates. I took it all off, it's not the gearbox shaft but seems due to the slipper spring not actually being square on the flatted ends. I had a look and it's the same thing with my old Savage. Spur/clutch still mesh good but it's one of those thing that doesn't seem right. Anybody had anything similar?
Thanks for any advice regarding this combo. Don't really want to spend more on parts unless I have to!
