Clutch Springs
If you look, Site Jester did a review of these shoes also and did a lot of testing with different mills and weight setups. I'm running mine with no weights after reading it. I suggest checking it out, its got a lot of good info in it. I have 4 races on my one set and almost 2 gallons on my basher and the Nova shoes still look great. I have only had to de-bur the ones in my basher 1 time in the 2 gallons.
I will check it, thanks again..:resp:
Can you post the link to this,can't seem to find it
OK thanks oregon, might have to give these a try.:resp:
Scott, go with the 1.0's. ive asked around quite a bit, & got this answer from many whom i respect. the 1.1's are a stiffer spring & your clutch will engage at a higher RPM as the crank will need more centrifugal force to engage the clutch shoes 😛eace:
Thanks frddyj, looks like i will be placing the order soon..:resp:
