Changing size of spur gears.
Topdoggracer
Alberta
I just bought new spur gears today. Previously I have been running 52T and now they have recommended dropping down to 47T. I have bought a couple to give it a go and see how it runs. My question is will I have to adjust the mesh between gears or can it be swapped out with out any adjustments?
Any time gears are changed (spur and clutch bell), even if for the same size, it should be re-meshed. There are way to many variables that can cause the mesh to be bad if you don't.
Kind of thought you had to remove the engine to replace the spur anyway, maybe there's room to shimmy it... been a while. I say that because if you have to remove the engine, then your mesh would get jacked anyway, unless you remove the engine from the mount itself vs removing the engine and mount like I always do.
