center tank help
fastlane01
Ok I have seen alot of bada@# trucks on this forum and darn it I want mine to look like that! LOL If one of you could please tell me the FLM part #'s I need to convert I would be greatful. I want to get the heavy duty regular TVP's if possible the FLM45000.
i suggest going to the mid tanks build forums. theres tons of different tank set ups pick what suits you then we can help you assemble a parts list and how to do it.
If you want mid tank and low CoG, I suggest you spend a bit more for FLM45200 or FLM45100 (Extended). Then from there you can either make your own plate or buy FLM 45500. You will also need a tank, so I recommend either the MGT tank or the Mugen Tank. If you go the MGT way you will need a Rush battery box and an RPM receiver box. If you go the Mugen way you just need the CEN receiver and battery box.
I just ordered a set 45200 tvp's and all of the mid tank mod stuff. traded a set of terra pins for axial beadlocks and big joes
