cell test?
FallOut
well, found out my pack is a little screwed up. it seems to me that it isn't outputting enough current to power the rx ect. it isn't the wire gauge, hpi25 let me run his which had the same gauge. I'm gonna rip apart the pack and check the connections, and i wanted to know how to do a cell test in case its not the connections.
much appreciated,
FallOut
OK guys just to fill you in more of what is going on. He is running a spectrum and when using his hump pack sometimes it works but most of the time it doesn't power it up enough to bind. I took my pack and plugged it in and it worked perfectly and he ran about a tank, maybe more or less but it worked fine. As far as the cell test goes I'm not sure.....
Chris will probably chime in when he sees this post and help.
well charge it up and take a volt meter and test the current voltage if you have a bad cell or to it wont be the right voltage or mah
