kvnnets
- Location
- Oakville, Ontario, Canada
This might be interesting to some of you.
Thermal resistance: carbon fibre does degrade quicker as temperature gets hotter.
Water absorption: unless it's a really top quality carbon with good sealant resin, CF will absorb water and degrade in performance.
Contamination by chemicals: see below.
Oxidation: carbon fibre oxidise and looses strength as it oxidise. The oxidation level is quite low at room temperature but increases with temperature and also chemical contaminant
Durability. as seen above CF will not have durability in time as you have with Aluminium. So be mindful as your product will not be as good in 10 years with CF as it is in Aluminium.
Also failure mode with CF is much more difficult to predict, analyse and failure are not a controlled as Aluminium. CF will shatter when crack initiate from a minimal defect or chip.
CF tends to be more expensive than aluminum, but has some radar reflective (actually absorption) properties. CF has has good tensile strength but is not as flexible as aluminum...tends to crack under strain more than aluminum.
