Carb replacement on my savage 4.6
Place both side by side and compare, the needle length maybe different. Not a usual part to replace, what's wrong with it?
If you mean the rubber boot that protects the carb barrel from dust then they it should fit. A split boot shouldnt cause running problems.
No we're the carb slides into the motor there is a metal sleeve around the carb that was stuck to the block it did not come off with the carb I had to pry it out after I got the carb out
